07-19-2022 11:05 AM
07-29-2022 11:42 AM
@dust2dust wrote:Did you use the reset password link? If that's still not working then you'll need the support people to regain access. Then the new system has a way to reset the pin yourself.
@dust2dust Just for bit of gallows humour, I have successfully received the code to reset password and had every password I made rejected. CSAs still trying to get it sorted after 3 days.
07-19-2022 01:18 PM
contact to support team by CS_Agent
to reset pin, and check email and security question.
07-19-2022 11:17 AM
07-19-2022 11:15 AM
If you lost your PIN you have to contact agent and provide them new PIN. Agent can update but cannot see and tell you your current PIN.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
07-19-2022 11:09 AM
Thanks,i don't remenber i can't acess my account too
07-19-2022 11:07 AM
Did you activate yourself? Then you made it. You might have received it in a text after activation. Or you can reset it in the account.
07-19-2022 11:07 AM - edited 07-19-2022 11:08 AM
@Marcoecandrade hi you should have received one when you activated your account , you can log in to your self serve and change it to a new one in your profile
