How to contact PM porting team?
CashewPeanuts
I am porting out from PM to Fido. I tried inputting my IMEI but the request failed. I called Fido support and they updated request with my PM account number. I still haven't received any authorization text 30 minutes later.
Fido called me and requested I contact PM Porting Team to manually validate / verify the authorization.
How do I contact PM porting team? I opened a ticket with CS_Agent over an hour ago but haven't received a response.
Any help would be appreciated.
CashewPeanuts
While what you say may be correct. Porting is a two way process. PM needed to approve the request for the porting to complete. It was getting stuck on PM's side as the 1st request had IMEI. It took 3 cancellations and 4 submissions for it to finally go through. Fido agent said they had to contact Telus technical support to fix it.
I was provided that same number by @slusagm on this forum. Fido, Koodo, PM forum support all gave same number. That number is just a useless bot that keeps saying "there is no porting request for that number" and  doesn't connect you to a human.
It was disappointing to learn that PM has no support on weekends, contrary to what it states online. Porting is a time sensitive activity and a 1 day delay results in your billing cycle for old carrier to start again. I received a response from PM today, on Monday, 2 days after the ticket was opened and the porting is already done. Don't think I'll ever be coming back, its in these moments customers learn the truth.
@CashewPeanuts wrote:
I already opened ticket 5 hours ago, that was the 1st step I took. There has been zero support response. Fido/Rogers are trying their best to complete the port. I responded Yes to a 2nd authorization SMS at 2:20PM, hopefully port completes now.
Update: Received a msg at 4 PM that port was cancelled because I didn't respond Yes?? I called Fido port team and they submitted a new port request. I responded Yes right away. Agent confirmed he can see the approval. 20 mins later I see the request was completed on Fido side. Waiting for completion text.
I received zero support from PM during this porting process...
When porting to a different carrier, it's the new carrier (Fido in this case) that is to provide all support.   So, it's actually Fido that was giving you the run around having you call Koodo/Telus/Public Mobile.  Also, Fido gave you a phone number that handles only incoming number porting to Telus.  Fido is to provide all assistance and troubleshooting relating to porting a number to them, including them contacting Public Mobile if necessary rather than them trying to get the customer to do something they're responsible for taking care of.
CashewPeanuts
CashewPeanuts
TL;DR: Fido resubmitted the port request and cancelled the initial one. I received the authorization text.
Overall this was not a good porting experience. The initial porting request didn't complete because I used my IMEI instead of my PM account number. I called Fido port team and they updated the request, they said IMEI only works if you bought the phone from the provider. There is no tip anywhere that says that. I still didn't receive an authorization text 1.5 hours later.
Fido asked me to call porting team. I call that number and the automated system says there is no port request and then connects you to Koodo support. The bot says to use chat to talk to an agent. I use chat to get a call back from an agent, the agent says they don't support PM and I should use the PM forum and gives me the same number. I told him that's a Koodo support number and doesn't allow speaking to a port team agent ... I was going in circles.
Fido/Rogers port team agent called me back and said they will cancel the port request and resubmit it. It may cause issues in the back end but they'll work with Telus to resolve.
I responded Yes to the port SMS confirmation. 2 hours later received a text from Fido that this is a duplicate request? Then 15 mins later got a call from Fido/Rogers again, they are canceling and resubmitting the request. I responded Yes again to new SMS confirmation.
slusagm
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
