How to change plan- downgrade
jackie33
How do I downgrade more on a plan as all the options are not showing. I want way less data right now changing to $30 plan but i want the $20 plan i can see online just not on app thanks
I have never been able to contact support keeps saying error on app and tried many times with many different ways as well for the last year
Yummy
Downgrading plan become very difficult as PM removed that option for some accounts.
If you do NOT see lower cost plan then it is not available to you anymore. Opening a ticket will NOT help unfortunately.
Sansan
Regrettably,  you can only change plans to what is offered in your own account.  Very few options now to downgrade.
But if you do downgrade, be sure to select Change on Renewal,  to finish out the current cycle as there will be no pro rating.
HI @jackie33
not all plans are available for everyone.
It looks like the $20 plan is only a special offer for the $15 plan subscribers.
And for your problem with ticket submission, maybe you can message support agent directly here
