How to change my plane before reactivating it?
Matejj
I am currently long therm overseas and don't need my 50,- plan. I would like to change it to 15,- and then reactivate as I don't need service at all. I just want to pay the minimum to keep my number.
I tried to top up my account with 15,- and then change my plan, but it's missing that option. It wants me to pay 50,- and then I might be able to change the plan next month.  I am sure it must work somehow, I am just unable to call a real agent as I am overseas.
they might have new nplan when he is back. 😀
@Matejj
It is trickier to change plans in a suspended state, but it is possible.
See the following thread:
https://productioncommunity.publicmobile.ca/t5/Announcements/Systems-Update-Ability-to-change-plan-w...
As stated above, when you get back to Canada and want to change back to $50 plan, you may need to pay extra for the $5 for Canada wide calling.
HALIMACS
@Matejj
As far as I'm aware, the $15.00 plan is no longer available to be activated, or changed to, IF YOU WISH to retain Canada-wide calling as part of the plan.
If Canada-wide calling is unimportant, and you simply wish to retain the service, you should be able to select the $15.00 Province-wide plan.
Triguy
You could change plan immediately.
https://www.publicmobile.ca/en/on/get-help/articles/change-your-plan
If you still need assistance then submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work
