How to change my physical card to a eSim card
liskrbcq
Hello Guys, I am using a PublicMobile Physical Card, how can I change it to a sSim card. Appreciate your help.
Andy85
Hi @liskrbcq,
Just so that we understand your situation better, why are you looking to switch from the physical SIM to eSim? The physical Sim can be swapped into a new phone if you are planning to shop around for a new device. The eSims cannot be moved from one device to the next so there are drawbacks with eSims.
TheSterlinger
First make sure your phone is phone compatible. Sign onto My Account click the shop button and press eSIM and pay.
https://myaccount.publicmobile.ca/en/account/purchase-sim
@liskrbcq  I wouldn’t do it if I were you I prefer physical sim . But if you want to download the app on the phone you want eSIM and log into your account go to subscriptions add on page . Notice in my screen shot at the bottom “shop SIM card now “ tap it and select eSIM download it and install that’s it
