04-24-2025 11:04 AM
05-20-2025 11:53 PM
There is no discrimination here. You just have a plan that doesn't cover Korea. And that plan doesn't include France, Germany, Spain, Australia, Japan, Italy or other high GDP countries either. I purchased "300 International Long Distance Minutes" using 10 rewards point which was free. You get 1.75 points every months. If you have been with Public Mobile 6 months or more, you should have that point. I had no issues with making calls to Korea. If you don't have that point, you can purchase it with 15 CAD. And it never expires. It is worth.
04-24-2025 05:35 PM
So Public mobile discriminate countries
04-24-2025 05:33 PM
@vancityjun wrote:My subscription already includes 100 long distance mins
For plans that include a set amount of long distance minutes, these minutes only include calling to China (including Hong Kong), India, Pakistan, Philippines, Taiwan, and the UK.
04-24-2025 05:30 PM
04-24-2025 11:07 AM
Public Mobile has a $15 add-on that you can buy to call South Korea.
04-24-2025 11:06 AM
to call South Korea, you need to buy the 300 International Long Distance Minutes add on for $15 (login to My account -> Subscription and Add-on page)
after you bought the addon, just reboot the phone, and then you can make calls by daily 011-82-area code dropping leading 0 - localNumber
