How to Unblock Callers from Leaving a Voicemail (Option 5 on the setup of Extended Absence Message)
trooper0169
I am trying to reverse my Extended Absence Message and reverse the Option #5 that doesn't allow the caller to leave a voicemail.
Thanks trooper0169
trooper0169
Thanks
  • dial into your voicemail and log in with your PIN.
  • In the main menu, press 3 (manage greetings),
  • then 4 (manage extended absence greeting),
  • then 4 to turn off your extended absence greeting
trooper0169
Select option 5 to block callers from leaving a message after hearing the Extended Absence Greeting (I have done this and want to reverse it)
This is what I what to Unblock and then go to my regular voicemail greeting and allow voicemail message from callers.
