How to Recover Deactivated Account
mohyi
Hi, I had a public mobile pay as you go plan. 4 days ago, my plan was deactivated because of inactivity. I had been trying to re-activate it for the last 2 weeks, but kept getting an error.
As far as I can find online, my only option seems to be to sign up again from scratch. Is there a way to recover this deactivated line?
9 REPLIES 9
@mohyi wrote:
Also, if I have to get  a new account from scratch, and my phone number is back in the number pool, how do I request that I get the same number back?
@mohyi   if you got your number from PM (or Koodo or Telus) and it was deactivated not long ago, and the number has not been picked yet, there is a chance.  We saw people reported that PM support willing to help.  But again, you need to message them and ask
mohyi
@mohyi   your account is really deactivated (permanently closed).  So, your last payment date was over 120 days ago and your account was suspended over 90 days ago
Again, there is a slight chance to get the number back if you wish, open ticket with support and discuss with them. if they agree, then you will need to buy a new sim card and activate a new account and Support will help.  Please note when you join PM again with this new account, you will be on the new Public Points rewards system
mohyi
My last bill was Jan 12th, and it says my account expired on the May 11th. So it sounds like I should still have access to my online account, yet I'm unable to log in
mohyi
It just says "having trouble finding your account"
Korth
If your account isn't paid then it gets suspended. No service. Self-Serve will say your "Plan is Expired".
But no worries (aside from not having active phone service), your account will remain suspended for 90 days before it is permanently terminated. At Public Mobile there's no additional charges for the deactivation and for reactivation. Like all other prepaid phone plans, you don't have to pay for the days your plan wasn't active. Your next prepaid 30-day billing cycle begins the moment payment is accepted.
If your account has been terminated (after 90 days of being suspended) then it's gone forever. Any funds deposited into it are gone, any Add-ons or Promos or Rewards attached to it are gone, the SIM card attached to it is permanently deactivated (can never be used again), the phone number is gone (reassigned to the number pool). The only option at this point is to create a new account with a new SIM card and new phone number - although at least you can take advantage of any promos which are for "new customers and new activations only".
If you're having trouble logging into Self-Serve then try clearing your browser cache and cookies, then close and restart the browser. Or try a different browser. On a different machine if you want to be sure. And disable any scriptblockers, adblockers, things like Ghostery while visiting the site. Some people will recommend using Incognito/Private mode on your browser, though this shouldn't be necessary (and I think that while it can solve some problems, it can also cause others). If you've been banging against Self-Serve login errors often enough to get rejected then perhaps wait a few hours or a day before trying again, servers often reject or "ban" access for a short time after repeated guesses/attempts which appear to be brute force hacking attempts.
dust2dust
Dial 1-855-4pu-blic and enter your number. If it says suspended then good. If it says invalid then not so good.
If you last paid over 4 months ago while not having a balance then it would be fully deactivated.
If the account has been in suspension for 90 days, your account has been permanently closed.  If it's been less than 90 days, service can be resumed by making a payment to pay for your plan.
@mohyi was it suspended or deactivated??  account will only be deactivated if suspended for over 90 days. When was your last payment date?
If suspended only, you can try to login to make payment to resume service
if deactivated, you need to get a new SIM card activate a new account.  You can also try to contact support and see if they can  assign you the same phone number
