01-13-2024
11:48 AM
01-13-2024
01:39 PM
computergeek541
How many times can one change their phone number?
01-13-2024 01:51 PM
@Chalupa_Batman wrote:I guess you guys could be correct. I was looking at an older post. So, @computergeek541 do you have a source link for this 4x every 30 days where it states this?
I don't recall ever coming across the infromation myself in the helip articles. It's just something that I've known. I believe that I was one of the first to advise others of the change to allow 4 phone number changes per 30 days.
01-13-2024 01:50 PM
01-13-2024 01:47 PM
01-13-2024 01:40 PM
@Chalupa_Batman wrote:Hey @El_Gato
You are permitted to change it as often as you like. However they limit it to once per 30 day cycle. If that is what you're looking to do, it would be better to just grab a VOIP app like TextNow and just erase it every 30 days and use a new email address each time. I used to do that during the pandemic.
Handy1 is correct that the limit is 4 times per 30 days. It hasn't been limited to once per 30 days for quite a while.
01-13-2024 01:05 PM
Unless something changed I can only go by this from public mobile
01-13-2024 12:13 PM
Hey @El_Gato
01-13-2024 11:49 AM - edited 01-13-2024 11:49 AM
