12-23-2021 09:03 PM - edited 01-04-2022 04:50 AM
08-28-2025 09:58 PM
Same with me
12-24-2021 12:22 AM
@Anonymous wrote:do you get new number or port old number to public mobile.
I know that this customer took a new phone number, but even if a number port in was requested, that would not cause there to be no service for 24 hours.
12-23-2021 10:48 PM
It will take up to 3 days for PM staff to enter your free 2gb bonus data.
If it is not entered after 3 days, contact the PM CS_Agent and create to ticket for them to look into it for you.
12-23-2021 10:01 PM
Hi @ShawnKing Activation should be instant. But what phone do you have? Did you try your PM SIM on another phone?
If you tried a second phone and same result, open a ticket with PM.:
click on the Bubble on the lower right or directly at : https://publicmobile.ca/chatbot
Follow these these to get to ticket open page quicker:
12-23-2021 09:58 PM
@ShawnKing wrote:Signed up yesterday. Still no service as of 24 hours later.
@ShawnKing if you were charged for the SIM card activation, what other trouble shooting have you tried?
*Can you try another working SIM card in your phone, to ensure there is not a device issue?
*Could your phone be locked to a previous provider? If so, contact them to unlock it for you.
*Check to see your phone is not blacklisted: https://www.devicecheck.ca/check-status-device-canada/
12-23-2021 09:41 PM
If the activation was successful, your phone should work immediately.
Did you encounter any difficulties or errors during activation?
Did the payment show up on your credit card?
Could you set up your self-serve account with the phone number?
When you put the SIM in, do you see any message on the phone or hear anything when calling 611?
12-23-2021 09:09 PM - edited 12-23-2021 09:10 PM
@ShawnKing wrote:I'm activating on a new number.
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
or visit Here link,
APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
Select the brand and model of your phone,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
12-23-2021 09:08 PM
12-23-2021 09:05 PM
