How do I login to my account. My email doesnt work
Heart1974
gblackma
@Heart1974 do you mean that you no longer have access to the email?  Or that you can't log into your self service account?  If you have access to the email account, try the forgot password link to get back into your self service account.  If you no longer have access to the email, or you cant access it, contact the moderators. If the former, give them the email address that you would like your account associated with.  If the latter ask them for a temporary password to your self service account. If both, ask them for all 2. There are 2 ways to contact the Moderator Team:
  • Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password.  Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen.  The mods answer will show up there.  When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
Has your self serve account ever worked?
Or did you recently join PM at a kiosk or retail store?
If you joined at a Kiosk or retail store. Most don't make your self serve account unless you request it. As you have to set up a password,etc.
Try creating one at this link.
https://selfserve.publicmobile.ca/self-registration/
If self serve used to work for you. Try the forgot password link.
https://selfserve.publicmobile.ca/forgot-password/
Do you receive an error message or anything?
Is your account active? Can you dial 611?
Will await further details from you!
Dunkman
@Heart1974
Are you able to reset your password?
If unable to reset password, you will likely need to contact moderator.
Click on question mark on right lower corner of website.  Type: contact moderator.  Follow prompts to submit ticket to get moderator help.
Hi @ @Heart1974 ,
Why doesn't your email work? What error message are you receiving?
Create a self serve account, click here:
https://www.publicmobile.ca/en/ns/get-help/articles/create-a-self-serve-account
