06-22-2018 11:18 PM - edited 01-04-2022 06:16 PM
When I initially signed up with Public Mobile at the local Walmart store, I was never asked who referred me to Public Mobile. A security guard at my wife's work is the one who told us about Public Mobile. Is it possible to retroactively give him referal credit so he is properly rewarded?
06-23-2018 01:37 AM
I have 2 referrals, and referred a third, but the meathead put my wrong area code in so I lost out on that as it cannot be done retroactively lol
I've learned my lesson though, when it comes to referrals, make sure it is done right at the beginning before activation and make it very clear what number should be used.
06-23-2018 12:07 AM
the only real way would be to use your current plan and when you are close to renewal port to another company, then port back to pm using your friends number. if you do use a referal on teh secont time round you will get $10 which covers the cost of the sim thanks to the new referal promo. you just need to find a cheap sim.
06-22-2018 11:21 PM
Referrals must be added to your profile at activation and can not be added retroactively.
