How do I change my sim card number
mnvspatel
2 REPLIES 2
dabr
@mnvspatel   Login to your account and select Quick Links menu (top right of page) and then Change SIM, you can also select My Profile from the left side of page and should get options to Change SIM there as well.
Yummy
Do you mean how do you replace SIM? From Profile:
