How do I change from a 1 month to 3 month subscription.
JDBlue1966
I currently have a one month subscription plan. How do I change it to three months?
@JDBlue1966  Another thing to watch out for when trying to select 90 day plan is you first need to select the plan itself and choose between 30 day or 90 day don’t miss it
HI @JDBlue1966
as said above, only 1 plan now has the 90 days option
But I don't suggest you to change the the 90 days option especially for high $ plan.  90 days option is pretty much a 90 days contract.  Many regret as they see price dropped shortly after their 90 days plan kicked in.  Yes, you can still change after the end of the 90 days without losing money, but you will be in a better position if you are in a 30 days plan
JDBlue1966
Thank you
hairbag1
@JDBlue1966
there is only the 1 plan that you can have for 90 days. If you want that one, make your selection but I suggest you Change on Renewal.
@JDBlue1966  Only the plans that say it in the plan description have the 90 day option like this one @JDBlue1966
