How do I Change "to no plan with add-on" from monthly plan
10-15-2018 06:11 PM - edited 01-05-2022 02:09 AM
10-15-2018 09:07 PM
@Anonymous wrote:iirc someone here (not someone_here) has been riding their 200 minutes for like 2 years or something.
I am one of the those with the 400 minutes add on. Bought April 2016 and only used 329 of 400 minutes. So by the time it is used I will have reached 3 years of usage of one add on.
10-15-2018 06:19 PM - edited 10-15-2018 06:19 PM
Yes, thats not possible. An addon is something added to an existent plan, without a plan the addon won't stay.
10-15-2018 06:17 PM - edited 10-15-2018 06:18 PM
@PhilipCho wrote:I'd like to remove my monthly plan and only use add-on.
Because I do not use my phone much.
How can I do to do it?
You can't.
The best you can do is the minimal $10 plan offered.
