11-03-2016 09:22 AM - edited 01-04-2022 04:14 PM
Hi,
I just ordered a SIM card after inputing the IMEI number. You will send me the matched SIM card for my iphone 5 baed n IMEI info?
Thanks,
11-03-2016 10:08 AM
NP @peterzhangon glad to help! thats what's great about PM we all help each other out.
11-03-2016 10:05 AM
It is amazing!
Thanks a lot for your strong support.
11-03-2016 09:44 AM
Below is a picture of the sim card, helps explain how all three are in 1!
11-03-2016 09:34 AM
@peterzhangon, @CaNuCk07 is correct. The sim is 3 in 1 and will fit your iphone. You can use it as a standard, micro or nano sim.
Hope this helps.
11-03-2016 09:33 AM
My SIM card order number is 87128.
Can you help to confirm the SIM card is for iphone 5?
I did not remember to see the phone type after querying IMEI.
Thanks,
11-03-2016 09:26 AM
Hello! the sim card you will receive, actually has all three sizes of sim card all in one. All you have to do when you receive it is pop out the proper cutout that fits into your phone!
