How can I get my PUK code?
Jmssgagne
2 REPLIES 2
GinYVR
@JmssgagneThe default code is 1234 but if you have changed it, you will need to contact the moderators..
will13am
@Jmssgagne , puk codes are provided by the moderator team. The moderator team can be reached via private message using this link.  Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
