How can I check my 2 public mobile minutes? If I didn't put them on yet
05-11-2020 05:37 PM - edited 01-05-2022 10:45 AM
05-11-2020 06:38 PM
@Melissakisey78 to save more, add the TextNow voip app and use it via Wifi to make / receive / send calls and texts in Canada and to the United States for free. You can also use it as I do to check my voicemail from my own phone without using the minutes from the PM plan. Simply dial your PM phone number - reject the call when it rings (this sends the call to voicemail) - press the * key to allow you to enter your password. - enter - and you are in your voicemail account - Hang up when you are finished. No minutes used.
Welxome to PM. Stay safe.
05-11-2020 05:44 PM
@Melissakisey78 Do you have 15$ plan? Then login to self-service, and it will show. For plans higher that 15$, mins are unlimited. Stay safe!
05-11-2020 05:40 PM - edited 05-11-2020 05:50 PM
Kind of guessing how the rest of the question goes. Log into your self-serve (each has a separate login) and you can see your usage. If you are on a limited plan I have read here that people can call *611 and hear their usage. I do not have this plan and can't verify that it works.
Edited to add: I just checked *611 on my son's phone and it doesn't give minutes remaining oh his $15 plan but it gave what is remaining with his add-ons.
05-11-2020 05:38 PM
Go into self serve account. Selserve.publicmobile
It will show how many minutes remain in your plan.
