no data
05-11-2020 05:11 PM - edited 01-05-2022 10:45 AM
I have having problem with my data
no internet connection, phone call works fine
happened a week ago as well?? service came back later
it is happening again
what is going on?
Phones
07-27-2020 12:41 PM - edited 07-27-2020 12:42 PM
@JaneMangat it should reset to the original factory metwork settimgs and once your phone restarts should take the correct PM network settings. The ones that allow you to send mms messages and to surf the net.Stay safe.
07-27-2020 12:35 PM
Hi, thanks for all of your information regarding an iphone and the issue of no longer getting data. In my settings on Cellular Data my APN is sp.mb.com then there are only two other options which are Username and Password. I have left both of these blank. The only other setting is Reset Settings. Should I do this? If I do it it says that it will reset all my network-related settings to their original values? What does that mean ? Thanks for your help in advance.
Jane.
05-11-2020 08:55 PM
@JL1 wrote:I have having problem with my data
what is going on?
can you check the APN settings on your phone? maybe for some reason the APN settings got changed thats why data is not working
05-11-2020 06:24 PM - edited 05-11-2020 06:26 PM
@JL1 you can report it at https://downdetector.ca/status/telus/
05-11-2020 06:17 PM
Thank you everyone
I tried everything and it was still not working
And now it suddenly work again
Is there any place I could report outage or something like this in the future?
Thanks
05-11-2020 05:47 PM
Can you try this,switch on Airplane mode and turn off your phone. Wait for half a minute and then turn your mobile phone back on. Go to the same settings section and turn off Airplane mode. After that, check if your mobile data is working again. Give it a try.
05-11-2020 05:44 PM - edited 05-11-2020 05:49 PM
@JL1 wrote:Sorry
I wasn't clear in my message
I meant it is a network problem
I have data quota
I have also restarted my phone and tried everything
But my internet is not working
Which phone are you using?
Put you PM SIM in another phone to test for data. If it works in another phone, it is not PM network issue.
05-11-2020 05:44 PM
05-11-2020 05:40 PM
Sorry
I have data quota
05-11-2020 05:32 PM
If you had used all your data for the current cycle, options to get more data:
1. If your current data limit does not meet your 30 days' need, you may change a plan with more data. You can do the plan from self-serve. You get your data back immediately with plan change.
2. If you want to renew the same plan early, you need to create a moderator support ticket using the ? button at the bottom right hand corner of this page. Moderator wait time is 2 days. If your next renewal date is up to 2 days away, you may just on data diet for a few days until after renewal.
3. You can buy data add-ons $15 1GB data or $10 200MB data. Expensive option
05-11-2020 05:29 PM
Did you received 75%, 95% and 100% data usage warning text messages?
If yes, you had used all your data for the current cycle.
This explained why your data was gone and came back after your renewal and now all your data were used.
Check your data usage line on your account. If you do not see the data usage line, you had used all your data for your current cycle.
My data usage line is showing that I used 73.007MB ouf of my plan 250 MB my current cycle. If you do not see a similar usage line, you had used all the data.
Data & Add-Ons Amount Used $0 Free Holiday Giveaway: 1GB Add-on140.206 / 1024 MB$0 Free Holiday Giveaway: 400min INTL Long Distance (incl CA & US)1 / 400 MIN100 Minutes Canada-Wide Talk40 / 100 MIN1GB Promo102.004 / 1024 MB250 MB at 3G speed73.007 / 250 MB500 min Canada-Wide Long Distance225 / 500 MIN
05-11-2020 05:22 PM
05-11-2020 05:20 PM - edited 05-11-2020 05:23 PM
@JL1 if your data was working before and it's not working now I wouldn't change my APN settings. try resetting your network settings. what type of phone do you have?
05-11-2020 05:19 PM - edited 05-11-2020 05:21 PM
@JL1 check your plan to see if you have data left. It should look something like this. Try restarting your phone. Puy your phone on aeroplane mode for 5 minutes. Take it off and restart. Stay safe.
05-11-2020 05:11 PM - edited 05-11-2020 05:16 PM
what is going on?
Are you sure you have data left? When was your renewal maybe you ran out last week then you had a renewal? if the data isn't showing on the OVERVIEW Page (when you first sign into self-serve), then it has been used up for your current cycle. Conventional thinking would suggest that the system display the data still showing 100% consumption. Unfortunately, the self serve is programmed to remove reference to data when it is all used up. If you don't see the data list in your plan details (I believe it's the Plans & Add-ons page), then you have an account issue and will need to contact the moderator team for assistance.
If you are sure there is data available in your plan and its not all used up then go into network settings and make sure "mobile data" is enabled. Restart your phone. Turn air plane mode ON then OFF. Do you have another phone to try your sim card in to see if data is working? Has data ever been working? Have you tried data on more than 1 app, have you confirmed you have no local data restrictions / firewall settings? Go into mobile data usage under settings and make sure you have not used your local "data limit" and there are no network restrictions
Go into network search and try reconnecting to the network and make sure LTE is set to preferred (even if you have 3g) If was already on LTE, then try switching to 3G, did it help? No? Then go back to LTE.
Does MMS work? (Not SMS) MMS uses data. Try sending a picture to yourself. Did you get it?
The most likely cause is the APN. You need to configure (Or re-configure even if you have already configured before) your APN settings to be able to send pictures (MMS) and navigate on internet (DATA). Your "Mobile Data" needs to be activated.
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Iphone
Settings > Cellular > Cellular Data Options > Cellular Network
OR
Settings > Mobile Data > Mobile Data Options > Mobile Data Network.
Name: Public Mobile / Mobile Internet
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
APN Tethering Settings:
Name: Tethered Mobile Internet
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
Authentication type: Not set
APN type: dun
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
