11-27-2016 12:20 AM - edited 01-04-2022 01:18 PM
11-27-2016 02:06 AM
11-27-2016 02:03 AM
If the phone is locked to the Telus/Koodo network you are ok. If it is an unlocked phone then you are 99% ok but as stated if it is from out of country you then need to check to see what bands it supports
11-27-2016 01:52 AM - edited 11-27-2016 01:53 AM
There are different models of iPhone 6.
For example: an Asia model might have issue in America. An America model might have issue in HongKong.
You may check your phone with model number on this site to see network compatibility.
https://www.frequencycheck.com/carriers/public-mobile-canada
Hopefully this helps you to resolve your question.
11-27-2016 01:39 AM
That's interesting. My phone is unlocked iPhone 6 plus (bought from Apple store).
Mine said my phone is fine when during my activation.
I will note that and give suggestions to others not to rely on IMEI checker. 🙂
11-27-2016 01:13 AM
@hslee1210 wrote:
If you bought your phone in Canada, I'm 99% sure that it will work. To fill that 1%, check your phone from the link below. Follow the steps and it will answer your question. 🙂 https://publicmobile.ca/en/on/get-started
FWIW I tried the IMEI checker and it told me that my unlocked iPhone 6S would NOT work with PM. Obvioulsy this was wrong as it has been working fine for nearly a week now. Just a heads up that the IMEI checker seems to be yet another thing not working right.
11-27-2016 12:36 AM
11-27-2016 12:31 AM - edited 11-27-2016 12:31 AM
it should work because PM uses telus network. put your sim inside the phone and try rebooting it
