12-02-2023 01:19 PM
Hi there. Since I started the new subscription I've been having issues with the hotspot going to my laptop. The devices connect but the laptop can not connect thru the phone to the internet. I ping the routers (phone) IP and they talk fine but for some reason the phone does not allow this conversation to go further. Phone is Pixel 6a laptop is MacBook pro. Wonder if you got any input on this. Thanks
12-02-2023 07:53 PM
@sdiep1 Public Mobile technical people are working on it, quite a few of us are affected
12-02-2023 07:51 PM
I am also unable to attain internet connection when using my Public Mobile hotspot from iPhone 14 Pro Max to my MacBook. The devices connect fine but no internet connection.
12-02-2023 04:38 PM
I did it myself this morning. If it doesn't work, then you've likely entered a typo.
12-02-2023 03:43 PM
Nop. Not only hotspot does nothing but the regular data conexión goes kaput.
Where did you get this from?
12-02-2023 01:45 PM
Go to settings, connections, Mobile Networks, and then Access Point Names. Create a new APN and enter in the following:
Name: anything you want
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
Save the new apn and then make sure it is selected. Hotspot should work now.
12-02-2023 01:23 PM
@Kike There is currently a known issue with hotspots so perhaps this is your problem, see
12-02-2023 01:22 PM
It's posted that it's a known issue that they're working on. Sorry just gotta wait
