05-14-2024 05:58 PM - last edited on 05-14-2024 06:01 PM by computergeek541
Hotspot on iPhone not visible to others (not on the same iCloud anccounr) until “Settings -> Personal Hotspot” is opened.
iPhone 14 Pro with iOS 17.5
i have tried another carrier’s SIM card in the same phone and found the hotspot is immediately visible to all devices around.
how can this fixed so the hotspot is constanly visible to all devices?
05-23-2024 11:32 PM
yes
05-22-2024 10:12 AM
yes
05-15-2024 02:48 AM
Thanks, there are no carrier updates showing. iOS, as mentioned, is 17.5 which was released this week.
05-15-2024 02:45 AM
I think the “allow others to join” is key here. The difference between a hotspot that is visible only to devices on the same icloud account (or other icloud family users) and a hotspot that is visible to all wifi capable devices..
05-14-2024 07:05 PM
and @SeanM42
you sure you were not setting up Instant Hotpot instead of Personal Hotspot?
Instant Hotspot only work on same iCloud account
this is instant hotspot
https://www.cnet.com/tech/computing/how-to-use-apples-instant-hotspot-feature/
05-14-2024 06:59 PM
HI @SeanM42
maybe you need one more reboot
but before reboot , make sure you update Carrier profile and iOS
05-14-2024 06:44 PM
changing the APN from isp.mb.com to sp.mb.com and rebooting did not resolve the issue. “Allow others to join” is and has been enabled.
The iOS name of the device/wifi network is alphanumeric and as was mentioned is visible (and only) after selecting “Settings -> Personal Hotspot” to devices not logged into the same iCloud account
05-14-2024 06:38 PM
FWIW my iPhone has sp.mb.com and username and password blank but my iPad doesn't see it until I toggle on Allow Others to Join. But the OP already has that toggled on also.
05-14-2024 06:33 PM
@SeanM42 - Try under "Cellular Data Network" and enter this information:
APN: sp.mb.com or isp.mb.com
Username: {Blank}
Password: {Blank}
And reboot device, also try to enable "Allow others to join"
Or maybe your iOS name has a character that doesn't like it on Wi-Fi.
PM also has hotspot free.
05-14-2024 06:20 PM
yes “others” refers to other wifi devices that can list available networks. the list on multiple devices does not include the hotspot configured with “Allow others to join” on the iPhone
05-14-2024 06:18 PM
yes
05-14-2024 06:03 PM
I gather the 'other's you write of are refreshing their available connections in their wi-fi settings to see if your iPhone hotspot is displaying?
Perhaps it's in the list --- just somewhere not as obvious.
This does sound odd, for sure...
05-14-2024 06:01 PM
@SeanM42 Do you have Allow Others to Join enabled?
