Hot spot
MelissaB24
Can data with public mobile be used to create a hot spot? I do not have wifi in my home so I use my data to watch movies on TV. If there’s anything data is not shareable then Public is not for me. I check through the community and see others talking about not being able to create a personal hot spot.
2 REPLIES 2
hairbag1
@MelissaB24
if there's no usable wifi in your area...consider Starlink mini. It's kinda pricey, but it'll provide you with a robust high-speed wifi signal to use at home and on the road.
Phil_Adelphus
@MelissaB24   Yes Public Mobile supports hotspot.  I use it instead of the wifi router when we have a power outage.  There is some kind of glitch sometimes peculiar to iPhones where a pop up says to contact the carrier but PM doesn't disallow hotspots (I've never had that problem when using the hotspot on my iPhone FWIW)
