03-15-2024 02:38 PM
my mobile hot spot on my iphone 8 says to contact public mobile ? I have rebooted my phone, any solution?
03-21-2024 11:34 AM
What worked? I am having the same problem.
03-15-2024 09:52 PM
That worked , thanks!
03-15-2024 02:48 PM
@1413 reboot it once more and confirm mobile data works before enabling hotspot
03-15-2024 02:46 PM
No change, any other solution?
03-15-2024 02:43 PM
PM does not block the use of hotspot. Please check your APN settings
on Iphone:
Check APN, go Settings -> Cellular -> Cellular Data Network -> PERSONAL HOTSPOT / APN -> sp.mb.com , and Leave Username and Password blank.
03-15-2024 02:39 PM
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
