Home phone number being auto-rejected
Blurobin
Hi, I dont know if this is the right place to ask this question. My home phone number is a private number. When someone calls my cell from my home phone number, it is being auto-rejected. Does anyone know if and how I can fix this?
Thanks
11 REPLIES 11
Then OP should put their home number in the contacts list.
HI @Terenia   don't be upset, you can reach them:
open a ticket with PM CS Agent at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
Terenia
I did this part on my phone but still, all private numbers are auto-rejected. I was told that it might be a setting done by Public Mobile but I can't check it because I can't get any customer service support from them. This automated help on their site is just useless.
Blurobin
Yes, thank you very much! I missed that setting when I was going through it yesterday!
Thank you so much for everyone's help, wasn't sure if it was a cell setting or public mobile.
ddeep91
@Blurobin wrote:
My cell is a Samsung Galaxy A70.
@Blurobin
For Samsung Galaxy A70 follow these steps to see if the blocked unknown calls are turned on
  1. Navigate to and open the Phone app
  2. Touch More Options and then touch Settings.
  3. Then, touch Block numbers.
You will be able to see the "Block Unknown Callers" see if that's checked. If it turns it off and unknown/blocked calls should come through. Here's how it will look like on your phone.
Block numbers from the Phone app
Hope this helps
Cheers
Blurobin
geopublic
@Blurobin  What device make and model are you using?
ddeep91
Thanks
@Blurobin
You must have the "unknown numbers" blocked in your phone settings.
Open your calling app > on top right click 3 dots > click 'Blocked' > call blocking rules
In that menu you should see  "block unknown numbers/hidden numbers. Uncheck that option and calls should come through.
If you still have trouble accessing it. Just google "autoreject unknown (put your phone model here)" results will come telling you how its done for your phone.
Cheers!
iPhoneUser
Thanks
What happens if you call a different cell phone from your home number?
kselmak
Check your phone settings. There should be way too accept unknown and private callers
Jb456
Check your call block rules on your phone settings.
It might be that your phones settings have block private numbers.....
