Holiday Bonus
Yumyum1
I received a text for my holiday bonus which expires Jan.31, 2022. I replied YES2 today (Jan.31) and received a message the offer has expired. What's up?
7 REPLIES 7
haha @Yummy   earlier, I thought you were the OP with the post  Yum Yum Yummy  🙂
Yummy
Just contact agent to manually add bonus to your account.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
HI @Yumyum1   this is the holiday bonus running from Dec 1 to Dec 31 2022.  Glad you come and ask before it expires.  No need to worrry, it has not expired yet.
CS agent can add the bonus back to you quick, please open ticket with them
(Also, if you are on new rewards system Public Points, you will be eligible for another 1GB bonus.  Please login to My Account and go to the Catalogue section and add the Free 1GB Holiday data bonus
To open ticket with CS agent:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
HALIMACS
@Yumyum1
Public Mobile kinda messed up the timing of the expiry of this offer - you have until the end of day today.
Try logging into your self serve account, after clearing cache and cookies, and opening an incognito tab.
You may very well see it there on the right side of the landing page.
If you do not, definitely contact customer support promptly.
@Yumyum1 @You will need agents help to have the bonus manually applied
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community ( my preferred choice )
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
Quigley
@Yumyum1
You should probably reach out to a Customer Support Agent and ask them to add those holiday gifts manually to your account.
Use the Chat Bot Simon to get a service ticket started first.
@Yumyum1   it should expire Dec 31, 2022  🙂
no worry, this is the Christmas bonus everyone will get.  Please open ticket with PM Support and they will add the bonus back to your account:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
