12-29-2022
12:17 PM
12-29-2022
06:42 PM
computergeek541
I have not received the 500 international call minutes yet.
12-29-2022 01:31 PM
HI @spfang they usually reply quick. My friend got it back within couple hours after ticket opened.
so, check your Community inbox , envelope on top, for their reply
12-29-2022 01:30 PM
Thank you for your help. I successfully submitted a ticket. I'll wait and see.
12-29-2022 01:09 PM
Hi @spfang
same , just open ticket with CS agent as my post above. Let us know when agent added it back for you
12-29-2022 01:06 PM
I didn't get the 500 int'l call minutes either. I did receive the email saying we will receive a text message for the bonus but never got it. What can we do?
12-29-2022 12:23 PM
HI @Rosie3
do you get the bonus data ? You just don not have the LD minutes?
Please open ticket with CS agent and they will look into,
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
12-29-2022 12:22 PM
Did you receive the 2GB data promo add on?
Did you respond Yes2 to the promo text?
If you did, you might want to try to login to your account with a different web browser, clear cache or incognito mode. Sometimes you will be seeing the old cached version of the self service account.
12-29-2022 12:19 PM - edited 12-29-2022 12:21 PM
@Rosie3 @First try texting YES2 to 4911 if that don’t work conta agent to have manually applied
Getting help from agent , through automation
Or get direct help from a agent right here in the community ( my preferred choice )
edit act quickly offer ends dec 31 /2022
also if you have received the text and just do t see it in your account try going back in incognito mode
