Hi
AHachey1002
When im not in the internet range can I use my data instead to go online?
hi @AHachey1002
To turn cellular data on or off on your iPhone, go to Settings > Cellular > Cellular Data and toggle the switch to on or off. If your iPhone has multiple SIMs, navigate to Settings > Cellular > Cellular Data and select the desired SIM card to toggle cellular data on or off. You can also adjust cellular data options within Settings > Cellular > Cellular Data Options.
To turn on mobile data on an Android phone, you can either access the Quick Panel (by swiping down from the top of the screen) and tap the Mobile data icon, or navigate to Settings > Connections > Data usage and enable Mobile data.
AHachey1002
How do I toggle data
Yummy
As long as you have cell reception AND proper plan with data you can be on Internet. Just toggle data on your phone and enjoy.
@AHachey1002
Yes that is how data works. On your phone, within wifi, you will see the fan icon. When you are out of wifi range. It will show 3G, 4G/LTE or 5G but enable Cellular Data in your setting.
Sansan
Off course!!
How much data do you have? You have to monitor it and use accordingly.
Space it over the period of the 30 days.
Have you tried it yet?
Phil_Adelphus
@AHachey1002   Yes, you just have to make sure that cellular data is enabled in the phone settings.  You can have it switch automatically, for example in iPhones you would enable wifi assist and then the phone would just switch from wifi to cellular data as appropriate
