03-05-2015 02:46 PM - edited 01-04-2022 01:07 PM
Hi, I need sim card order but i don't know what kind of sim card i need. please let's me know.and send me message . thanks and have a good day.
03-05-2015 04:22 PM
03-05-2015 03:00 PM
More specifically, if you have not already registered for the beta program, go here http://publicmobile.ca/en/on/beta and sign up with your email address (if you are looking to activate multiple phones, you will need to enter one email per account you want to create).
Once you recieve the email from PM inviting you order the sim card, you will need the micro sim as noted above. Follow the directions that come with your new sim and you'll be up and running in no time!
Cheers
03-05-2015 02:54 PM - edited 03-05-2015 02:56 PM
Micro SIM, go to order your sim by entering your email, and wait for Beta tester email from PM
