Help
2009
Hi is There a faster way to get help?i activated my sims card and transfered my # but my card doesnt work so i have no service but the payment worked and they cancelled my other cell service so now im stuck no phone until they contact me
@2009   so, it is not connecting to PM network at all?
What kind of phone do you have?
but it sounds like a sim card provisioning issue.  No worry, easy and quick fix for PM support, you just need to open ticket to engage them:
1. Please open ticket via Chatbot (requires access to My Account): click this  Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
@2009
do you see Public Mobile as network ?
Try sim in a different unlocked phone.
Dial 611 from that phone...what does it tell you about your PM acct ?
2009
Hi thanks yes ive done That multiple time
hairbag1
@2009
first thing..try re-booting you cell phone ?
