Disabled Access
alissonnicolecr
Hi! I'm a customer and suddenly I couldnt use my data anymore I thought it ran out but when I wanted to check it I couldn't get into my account. After that it says that my email was invalid, I've been having an active plan. I don't know what happenned, can I do something?
HI @alissonnicolecr   it's good, your account is there 🙂
please submit ticket to CS agent then
alissonnicolecr
I can make and receive phone calls, what I cannot do is use my data and access my account.
I tried the "I forgot my password" and I put my email to see if the problem was my password but it said that it was invalid.
HI @alissonnicolecr  if you call 1-855-4PUBLIC, then enter your phone number, does the system able to find your account?
If it cannot, then did you recently made a charge back on any Public Mobile or Koodo charge with your credit card?
But if it can find your account, then you just need to try to reset the password or submit ticket to CS agent for them to help resetting it
Please submit ticket at : https://publicmobile.ca/chatbot.
First type Forgot Login,
HALIMACS
@alissonnicolecr
if you have access to a different phone, try calling your number and see what happens.
What do you hear when you dial 611 from your device?
@alissonnicolecr   first, can you make and receive voice call?
does your phone shows it connected to Public Mobile network? or it does not connected?
