Help
12-05-2019 10:13 PM - edited 01-05-2022 08:22 AM
Hi!
I was just referred to Public Mobile. I followed the steps online to set up sim card and transfer my number from my old provider.
Sim card is in the phone (iphone 7)... and I see public mobile at the top left of my iphone... I just got two texts from public mobile, one with my pin and the second one saying: Your transfer request has been completed successfully.
However, I tried calling my husband and I could hear him but he couldn't hear me then call failed.
And, when I open a text, it says:
iMessage is Signed Out
An error occured and your account (my number here) is signed out of iMessage. You may miss messages as a result. Please go to settings to address this issue.
Is this normal? How can I fix this? Thanks everyone...
Phones
12-05-2019 10:26 PM
I tried rebooting... didn't work.
12-05-2019 10:25 PM
Yes, my account was current.
12-05-2019 10:25 PM
You can also try a network reset.
12-05-2019 10:22 PM
To fix iMessage go to settings and then messages make sure iMessage is turned on then check the send and receive settings. Make sure your phone number is checked
12-05-2019 10:17 PM
@BDW wrote:Hi!
This may or may not work. Turn off the phone and turn it back on. Try the phone call again.
You may have to log into your Apple account on your phone to fix the iMessage issue
12-05-2019 10:16 PM
The first thing I would try is reboot your phone. Sometimes porting takes a bit longer than other times for some reason. Was your other account current? If not that can cause issues with porting the number.
