02-02-2019 11:52 AM - edited 01-05-2022 03:13 AM
Just reavtive my serivce and buy a new sim card and now it say emergency call and now unregistered sim card and it band new last nit3
Joining Public
02-02-2019 12:48 PM
Here's an additional resource to make sure your phone will work....https://willmyphonework.net
02-02-2019 12:43 PM
@Muldersarah7989 wrote:I put my sim card in the s4 and work
@Muldersarah7989. Sim works in one phone but in the other you get unregistered sim? It's definitely a phone issue and I would check the Canadian blacklist with your phones imei
02-02-2019 12:31 PM
Yez
02-02-2019 12:30 PM
You have to enter your new numbers of your sim in your account @Muldersarah7989...did you do it? CHANGE SIM CARD...
02-02-2019 12:23 PM
02-02-2019 12:22 PM
My son lost is sim card with is phome
02-02-2019 12:16 PM
Yes i just reactive it and npw my new sim csrd dont work
02-02-2019 12:07 PM
from what i remember unregistered sim message sometimes refers to phones being on the blacklist. is your phone new or used? have you owned it from the beggining?
02-02-2019 12:02 PM - edited 02-02-2019 12:04 PM
No need for a new sim card to reactivate your account as long as it hasn't been 90 days since it's expired. Just go into your self-serve account and top up with appropriate dollars. Good luck.
02-02-2019 11:58 AM
I'm trying to understand what's happened to you. @Muldersarah7989....you can't activate your new sim card but you have an account with public mobile??? Do you have access to your self serve account???
02-02-2019 11:56 AM
Walamrt and it brand new and i had to top up by feb 10 and i tops today
02-02-2019 11:55 AM
Hello @Muldersarah7989
When did you buy your sim card? And how long do you have stopped your account? If more 90 days everything is cancelled....
- « Previous
- 1
- 2
- Next »
