Help
Muldersarah7989
Just reavtive my serivce and buy a new sim card and now it say emergency call and now unregistered sim card and it band new last nit3
42 REPLIES 42
@Muldersarah7989 wrote:
Ripe off
I guess you mean rip off.
Muldersarah7989
Ripe off
Public mobile rioe me off
 @Muldersarah7989
What is rioe?
Muldersarah7989
MasonH
You have to sign into your self serve account and register your sim card there in order to activate it. You can't just put a new sim card that you just bought into the phone and expect it to work. Public Mobile doesn't register your service to your device, they register to the sim card in your device.
Muldersarah7989
K
PATIENCE again @Muldersarah7989...it's sunday!!! With no sun here but.....Smiley Wink
Muldersarah7989
3 hour ago i talk to a agent and nothi g nke
Muldersarah7989
Till waited
Muldersarah7989
There looking into it now
Muldersarah7989
Thank you for all your help i am talking to the agent now
Muldersarah7989
Sim card 1 my works in the s4 and my pone a5 2017
And sim 2 dont work in s4 or mg a5
Hello @Muldersarah7989
you have click on RESOLVED for your problem with the solution of Mimmo about the blacklist...,if it’s not the case and still no solution it would be better to let your subject unsolved for now.. if you want help...
Muldersarah7989
There the payment
edit by mimmo: removed image because it contained account number
Muldersarah7989
Yes i chamge the sim vard in self servce and say active
@Muldersarah7989 what happens
when you log into your sons self serve account what does it say?
Did you do the sim number change in self serve?
Can you post screen shots of overview and payment history pages?
Muldersarah7989
Yea it match it
@Muldersarah7989  I find it very hard to understand what has happened.
can you in point form explain
  • what happened
  • what does not work, what works where
  • what you have done
from piecing together the conversation
  • your son lost his phone so you bought
  • you now have two sim cards yours sim1 and your son's sim 2
  • and two phones s4 and a5
  • sim1(yours)  works in s4, sim1 works in a5?
  • sim2 (son) does not work in any phone
silly question but did you loginto selfserve and do a sim number update?  do the last sim numbers in selfserve match your sim
You need to wait now... few hours up to 2 days @Muldersarah7989 they will answer...
Muldersarah7989
The sim card dont work in my a5 2017 phone and mt sim card work in the sansung s4
Muldersarah7989
I did send a message yo yhen nothing yet
Muldersarah7989
My son phome work wirh my sim card
Did you write to the moderator @Muldersarah7989?
https://productioncommunity.publicmobile.ca/t5/notes/composepage
moderator_team in SEND TO and explain what happened....
but it looks like that is your son's phone the problem....
Muldersarah7989
the phone work my sim card just not my son and when it in my a5 2017 it dose work
Few minutes to 2 days...usually... @Muldersarah7989
Muldersarah7989
How long do u hahe to waited for port in
Click on this link and enter info about your phone. It'll let you know if the phone will work with PM. Sounds like the phone is problematic. Did you just recently buy this phone ?Good luck. https://willmyphonework.net
Muldersarah7989
No my sim vard work in the s4 and there other sim card done qork in my phome
