Help on plan details
Wendy14
Hi if I change my plan to 20gb 39$ will I lose my current loyalty and auto pay discount
Wendy14
Ok thank you
Wendy14
Thank you
@Wendy14 did you use Change plan now?
with Change plan now , PM will charge you full amount for that one transaction, you will get those rewards again in your next renewal
@Wendy14  No you get to keep your old loyalty rewards I can confirm I just did this and check  it out
You will still get those rewards after any plan change.
