02-08-2023 07:51 PM
I have no access to my email that’s on my account
I need to log in because it’s for my daughter and I can’t add money to it.
02-08-2023 08:04 PM
The primary question is: are the services working? If they are then you can log in and use the text method of verification. Or if you don't remember the password then you can use the reset password function to also send a text to the phone. This also works when suspended. (but not the account)
If the services aren't working then you have two other options: the dial-in method with either 611 on the device or the toll free mentioned earlier from any phone. If you know the 4 digit account pin then you can use the registered credit card. Otherwise you can buy vouchers in lots of stores or online and not need the account pin. Lastly there's the real time payment method in some stores.
After all of this then you could ask support to change your email. Or wait for support anyway. They might be somewhat fast.
02-08-2023 07:55 PM
Auto pay can fail
To make payment and reactivate plan .. if you know PIN number you can *611 with a voucher and *611 no PIN needed . You can also do this by by calling 18554PUBLIC . otherwise log into self serve make manual payment and reactivate service and or update credit card if necessary
My account
Legend and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
If you still have service and your plan renews today / tomorrow you can ignore this suspended notice
02-08-2023 07:54 PM - edited 02-08-2023 07:54 PM
You can reach out to support, or call 611 from the device and a Public Mobile payment voucher to apply funds to the account.
02-08-2023 07:53 PM
Hi @Anthonygray
open a ticket with SIMon Chatboth
typ: forgetting information
and Click, Forgot My account Email
then Click, Contact Us
and, Click here to submit a ticket.
or send a private message to CS_Agent
here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
02-08-2023 07:53 PM
Email is your ID at PM. You do not need access to your email in order to log in - just HAVE to know which email/password to use.
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
