07-05-2023 09:42 PM
Hey guys one of my accounts has an expired credit card so it stopped working, I’m trying to get logged back into the account to update it and it keeps sending me a text with a security code to the inactive phone. Sort of a stupid way for this as it can’t work this way. Normally it should send code to email but no, it goes to the phone which doesn’t work. How can I fix this? Tia
07-07-2023 11:44 AM
thanks but that screen to send email only comes up after trying unsuccessfully 4 times with the text thing. It should come up first
07-05-2023 09:45 PM - edited 07-05-2023 09:48 PM
If you have already created an EverSafe id, you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Resend code and then choose Send email
And If you can log back on thos way, go to the Profile page , click Manage EverSafe Id and change the phone number to the correct one
https://myaccount.publicmobile.ca/en/account/my-profile
07-05-2023 09:44 PM - edited 07-05-2023 09:46 PM
@MountainMaxMan2 Hit resend a few times do you not get an option for email instead to send code to . You. Can also get payment vouchers and load them 611
adding if worst comes to worse you can get support to update your credit card info also
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
