Help! Urgent
Izzy1992
I transferred my number last month and everything worker fine. I was gone for two weeks out of the country and just uploaded and it telling me I need to pick a new number. What happened to my phone number I had over a year!!
8 REPLIES 8
hi @Izzy1992 did yiu use another sim card on this phone  while you out of the country? if you did, maybe the travel sim messed you your phone settings and hence PM sim not connect? Try reset all networks  and it  could fix that
you can also try to call 1.855-4PUBLIC from another phone and enter your number, it will tell you if your account is active
If still have problem, please submit ticket with CS agent here
Izzy1992
It still active it even says send verification code to **34 but it won't send end have to get the verification code by email then after it tells me to get a number to complete activation
Izzy1992
No it paid 2 weeks later
Izzy1992
@Izzy1992
Try calling your number from another phone and see if it still works and also check your account and see if your number is still in your account and if your account is active.
It sounds strange if you didn’t apply to change your number. Maybe a phishing/spam?
will13am
@Izzy1992 , when you look at status of the mobile connection on your phone, what number is showing?  Does this number match the number showing on your online account profile?  If there is any problems and you need to get in touch with support, please use this link.
hairbag1
@Izzy1992
log in to your account to see if you still have an Active account.
Meow
Did you pay your bill on time (autopay)?
Log into your account and confirm your service is Active.
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
