Help - Porting in number from Koodo
Jtee604
Hi I need to port in my Koodo number to my Public Mobile account (already activated).
@Jtee604
What have you done on the porting process so we can help further?
Can we get more details?
If your PM account is activated, what issues are you having?
@Jtee604  If this is Koodo  pre paid you need support to help you transfer the number , if post paid in your account go to profile page and tap the transfer number under the top  red circle in my screen shot
Change # on profile tabs
link for support if it’s Koodo pre paid
send a  private message   To CS_Agents
HI @Jtee604
if your Koodo is a prepaid account, just submit a ticket with CS agent for them to help port over here, submit the ticket with this link
if it is Koodo postpaid, then login My Account, Profile, Transfer phone number. Enter the phone number and account number and follow the steps.  Once submitted, put your Koodo sim back to the phone.  Koodo will send you a text and you need to reply YES to authorize.  Once replied yes, you can put your PM sim back to your phone
