04-15-2024
09:32 AM
07-05-2024
10:17 PM
I called a guy the other day for my car, call went through no problem.
Today, I get an error that states "8B1 - your call cannot be completed as dialed, please check the number and try again. Or call client care at *611"
I did research it, but removing SIM card and reinserting did not seem to work.
Cellular data on, WiFi on
Account is paid
iOS 16.7.7 installed.
Seems to just be this number. Is it possible I was blocked from his end?
Thanks!
04-23-2024 08:43 AM
Thanks for the reply. I am going to assume its blocked since nothing else seems to work. Thank you for your reply. It is much appreciated.
04-15-2024 09:40 AM
It is possible that the other caller blocked you from his end. Especially if calling different numbers still work.
04-15-2024 09:33 AM
HI @Macorius
was it just one number you cannot call? can you all other number?
Reboot the phone first, then try to make a call manually putting a 1 in front of the 10 digits number. If it does not work, try to just call the 10 digits without the 1
