Having trouble porting my number
Lilselina
Today I recieved my sim card and followed the step for activating my sim. Received the confirmation number and finished setting up my account but then got a text saying "Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant at: https://publicmobile.ca.ada.support/chat
Which the chat didn't do anything. Tried to look through the community page and someone suggested calling Telus porting department but it didn't help. What should I do now?
2 REPLIES 2
@Lilselina  I’ll send porting  team number private message they can re trigger the port request for you and best to use old provider account number and ignore the IMEI . Or you can also submit ticket with support
send  a  private message   To CS_Agents
pmbc
@Lilselina I can send you a PM with the number of the porting team.  Not sure if it's the same one you called.
