Has anyone resolved error M.8702
Tala0
Hi,
has anyone resolved their issue yet so far? Please let us know what you did.
thanks
7 REPLIES 7
CSA_PM
Customer Support Agent
Hi there!
Can you please tell us more about the error ? Where do you get it?
ForestS
I did already.
@ForestS
You opened a ticket with PM?
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
ForestS
same error
Yummy
When did you get that code and what did you do to get it?
Never had ANY error code from PM, app nor web site...
@Tala0
send  a  private message   To CS_Agent
