HTC U11
Shockwave84
This phone is 4G LTE enabled. Is it compatible on the PM network?
Thanks.
Thanks.
No matter the model, a phone having LTE is not the only thing that you need to be looking for. If you're phone isn't compatible with Public Mobile's HSPA+ network, you won't be able to make any phone calls. While this is very important factor, to date, Public Mobile fails to mention this anywhere in its literature, causing customers to falsely believe that a phone will work fine just because it can connect to the LTE network (you need HSPA newtwork compatibility for voice).
Staliger
@Shockwave84 Yes, the phone should work with PM. Make sure it is unlocked.
popping
geopublic
Thanks.
@Shockwave84  Yes, it will work without any issues for both 3G and 4G LTE.
