03-02-2023
11:48 AM
03-02-2023
11:50 AM
computergeek541
I require assistance in setting up new PIN number to get into MY ACCOUNT.
Please contact me at xxxxxxxxxxxxxxxxxx
Thank you
03-02-2023 12:20 PM
@Yummy wrote:Only agent can modify this PIN for you. But you do not need it to log in. Only email and password are needed.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private message might take longer.
A customer support agent isn't needed to change the account PIN. This can be done from within Self Serve.
03-02-2023 12:15 PM - edited 03-02-2023 12:17 PM
03-02-2023 12:08 PM
HI @Sharmla
if you are referring the 2FA security code, it is a random code sent by PM system when you login, you will be given a choice to send to your email address or phone
the 4 digits PIN is to used for *611 or to open ticket
03-02-2023 11:52 AM
@Sharmla wrote:I require assistance in setting up new PIN number to get into MY ACCOUNT.
Thank you
Please note that there is no customer service available over the phone. Your account PIN isn't needed to log into your Self Serve. Logging in is done with your e-mail addresss and password.
