Group message not going through as sms
Jules22
  • I have a problem. Noticed one group message, messages sent by sms and not going through. However the other group message goes through as iMessage and goes through. How can I get my message go through sms. I did not create these groups.
9 REPLIES 9
CSA_PM
Customer Support Agent
Hi
I sent you a private message — you can reply by clicking this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
slusagm
@Jules22
ask PM to check or refresh you account for you
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
Or you can also message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
Jules22
Still not resolved. Tried everything tha is mentioned. I need to speak to an agent and it doesn’t seem possible. So frustrating
@Jules22   You've marked the problem as solved, is it working now?  If not, you need to have cellular data turned on for MMS to work whereas iMessage can use both data and wifi.  Also check in Settings - Messages - Send & Receive and make sure your phone number is checked.
Jules22
MMS is turned on
Dunkman
@Jules22
If a group messaging involves both android and iPhones, from my personal experience, I found some technical difficulties between the two different types of phones.  We used WhatsApp instead.
Is your MMS Messaging turn on?  From my understanding, group texts are usually send via MMS text (instead of  SMS text).
i would toggle off "Send as Text Message" and reboot and turn it back on and try
also, do you have RCS setup on your iPhone? that could be a problem if the group was using RCS and you don't have it properly setup
Jules22
Most probably android and iPhone
slusagm
can you confirm if some people in the group are using Android?
