10-06-2025 10:14 PM
Hello! I would like to refer my partner to public mobile and they would like the same plan as me, unfortunately this plan is no longer offered. Is there anyway that they can also have the same plan as me, since it it technically offered my public mobile. If this is possible how would I got about this.
Thank you!
10-06-2025 11:11 PM - edited 10-06-2025 11:11 PM
See if any one is wanting out of their plan and ask.
https://productioncommunity.publicmobile.ca/t5/Get-Support/My-2nd-number/td-p/1374568
10-06-2025 10:40 PM
Hello @Hlee12345,
Unfortunately what you see on the shop new subscriber site is what's been offered to new clients. I believe the cheapest is $20 for talk and text. And goes up from there.
You can provide them with your referral code for them to save the one time $10.
