09-11-2025 11:20 AM
I received the SMS text in order to transfer my number, I got everything transferred correctly, however, I can't receive calls, I can only make calls. Everything else works fine.
09-11-2025 11:31 AM
Hi, did you remove your previous SIM card from your phone yet? Once removed you should be receiving incoming calls.
Restart your phone and try again. If it still doesnt work, ask agents to check for you.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
'Contact Us', and choose your topic.
