08-10-2022 06:41 PM
08-10-2022 08:21 PM - edited 08-10-2022 08:23 PM
You purchased the wrong Add-on. The one you want is the 1000 minute US calling for $15 if you are calling from Canada.
The 10 days US talk and data Roaming will only work if you are in the US.
Contact a CS_Agent for a refund and explain your error.
08-10-2022 06:46 PM
They should be able to manually switch you from your roaming add on to a US LD add on which is competitively priced. (Relatively speaking)
08-10-2022 06:44 PM - edited 08-10-2022 06:47 PM
U.S add-ons roaming 10 day package working in U.S, not working from canada to U.S,
you bought wrong add-ons contact support team by private message CS_Agent to remove and buy it when you are visit U.S, or you need to make call from canada to U.S then you need to buy it other add-ons from canada to U.S.
08-10-2022 06:42 PM - edited 08-10-2022 06:45 PM
@Hussainsyed hi that add on is for 10 days while you are in the US it does not work on canada
