Going over calling minutes in plan
Bettycaligiuri
What happens if I go over the calling minutes included in my plan? Will it warn me? Can I pay $5 to add 500mins canada wide calling?
Thanks for the help!
TeaWhyElleAr
You can always add more in the add on section, just got to my account and clik purchas. There are all kinds of add ons at diffrent cost.
darlicious
@Bettycaligiuri  Most times you will get a text saying you've used up 90% of your calling minutes. Just add the $5/500 min add on and it will roll over every month til you use it up.
hairbag1
Get that $5 / 500 minutes add-on and you'll be able to talk Canada wide for an additional 500 minutes when your plan minutes run out.
Regular plan will just stop when you run out of your minutes...you won't be billed for overages.
