Getting customer service help
Meggerola
I have been trying to submit a help ticket to find out what email account I used to set up this account (long story…) but I can’t submit a ticket unless I have the account information.  I’m going in massive circles here. I don’t know the account number, I haven’t paid for any add-ones, and every time I try to reset the password and they send a six-digit code, it never arrives.  I just want to access the “My Account” section of the website!  The phone is my 12-year-old son’s, so we never set up an online account for him.  How do I get help???
Meggerola
Thanks!  I sent a message to an agent as suggested.
Meggerola
Thanks so much.  I’m trying the direct message approach.
Meggerola
Thanks.  Trying option 2…. I did option 1 four times to no avail.
@Meggerola @Try submitting ticket at bottom of my post
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
HALIMACS
@Meggerola
To contact a Customer Support Agent, there are 2 methods: ( use the 2nd method )
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
@Meggerola   try this
use Method 1 first and see if it works, it not , try Method 2
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
